osiris
Newbie
« : Декабрь 15, 2019, 15:27:50 » |
show proc cpu task Task Util (%) Avg (%) Max (%) --------------- -------- -------- -------- AMTR_ADDRESS 0.00 0.00 0.00 AMTR_ASIC_COM 0.00 0.00 0.00 APP_PROTOCOL_GR 0.00 0.00 0.00 APP_PROTOCOL_PR 0.00 0.00 0.00 AUTH_GROUP 0.00 0.00 0.00 AUTH_PROC 0.00 0.00 0.00 CFGDB_TD 1.00 0.16 1.00 CFM_GROUP 0.00 0.00 0.00 CLITASK0 0.00 0.00 0.00 CLI_GROUP 0.00 0.00 0.00 CLI_PROC 0.00 0.00 0.00 CLUSTER_GROUP 0.00 0.08 1.07 CLUSTER_TD 0.00 0.00 0.00 CMGR_GROUP 0.00 0.00 0.00 CORE_UTIL_PROC 0.00 0.00 0.00 DAI_GROUP 0.00 0.00 0.00 DHCPSNP_GROUP 0.00 0.00 0.00 DHCPSNP_TD 0.00 0.00 0.00 DHCPV6SNP_TD 0.00 0.00 0.00 DNS_RESOL_TD 0.00 0.00 0.00 DOT1X_SUP_GROUP 0.00 0.91 3.00 DOT1X_SUP_PROC 0.00 0.00 0.00 DRIVER_GROUP 2.00 2.00 4.00 DRIVER_GROUP_DI 0.00 0.00 0.00 DRIVER_GROUP_FR 0.00 0.00 0.00 DRIVER_GROUP_TW 0.00 0.00 0.00 DRIVER_GROUP_TX 0.00 0.16 2.00 ERPS_GROUP 0.00 0.00 0.00 FS 0.00 0.00 0.00 GVRP_GROUP 0.00 0.00 0.00 HTTP_TD 0.00 0.00 0.00 IML_RX 0.00 0.00 0.00 IML_TX 0.00 0.00 0.00 IP_SERVICE_GROU 0.00 0.00 0.00 IP_SERVICE_PROC 0.00 0.00 0.00 ISC_AG_HS 0.00 0.00 0.00 ISC_AG_LS 0.00 0.00 0.00 KEYGEN_TD 0.00 0.00 0.00 L2MCAST_GROUP 0.00 0.00 0.00 L2MUX_GROUP 0.00 0.00 0.00 L2_L4_PROCESS 2.00 2.50 19.00 L4_GROUP 0.00 0.00 0.00 LACP_GROUP 0.00 0.00 0.00 MSL_TD 0.00 0.00 0.00 NDSNP_TD 0.00 0.00 0.00 NETACCESS_GROUP 0.00 0.00 0.00 NETACCESS_HASH2 0.00 0.00 0.00 NETACCESS_NMTR 3.00 2.26 11.00 NETCFG_GROUP 0.00 0.00 0.00 NETCFG_PROC 1.00 0.16 1.00 NIC 0.00 0.00 0.00 NMTRDRV 0.00 1.00 3.22 NTP_TD 0.00 0.00 0.00 OAM_GROUP 0.00 0.00 0.00 OAM_TXLBK_TD 0.00 0.00 0.00 PING 0.00 0.00 0.00 PORT_SEC 0.00 0.00 0.00 PPPOE_IA_GROUP 0.00 0.00 0.00 RADIUS 0.00 0.00 0.00 SMTP_TD 0.00 0.00 0.00 SNMP_GROUP 0.00 0.00 0.00 SNMP_PROC 0.00 0.00 0.00 SNMP_TD 0.00 1.16 9.00 SNTP_TD 0.00 0.00 0.00 SSH_GROUP 0.00 0.00 0.00 SSH_TD 0.00 0.00 0.00 STA_GROUP 0.00 0.16 1.00 STKCTRL_GROUP 0.00 0.00 0.00 STKTPLG_GROUP 0.00 0.00 0.00 STKTPLG_PROC 0.00 0.00 0.00 SWCTRL_GROUP 0.00 0.00 0.00 SWCTRL_TD 0.00 0.00 0.00 SWDRV_MONITOR 7.00 3.48 7.00 SYSDRV 0.00 0.00 0.00 SYSLOG_TD 0.00 0.00 0.00 SYSMGMT_GROUP 0.00 4.25 37.00 SYSTEM 1.00 0.25 1.00 SYS_CALLBACK_GR 0.00 0.00 0.00 SYS_CALLBACK_PR 0.00 0.00 0.00 SYS_MGMT_PROC 0.00 0.00 0.00 TACACS_TD 0.00 0.00 0.00 TELNET_DAEMON_T 0.00 0.00 0.00 TELNET_GROUP 0.00 0.00 0.00 TELNET_SHELL_TD 0.00 0.00 0.00 TFTP_DOWNLOAD_T 0.00 0.00 0.00 TN0 0.00 0.00 0.00 TRACEROUTE 0.00 0.00 0.00 UDLD_GROUP 0.00 0.00 0.00 UI0 1.00 0.16 1.00 UTILITY_GROUP 0.00 0.00 0.00 WEBAUTH_TD 0.00 0.00 0.00 WEB_GROUP 0.00 0.00 0.00 WEB_PROC 0.00 0.00 0.00 WTDOG_PROC 0.00 0.00 0.00 XFER_GROUP 0.00 0.00 0.00 XFER_PROC 0.00 0.00 0.00 XFER_TD 0.00 0.00 0.00 sys_debug_proc 0.00 0.00 0.00
Vty-0# sh process cpu CPU Utilization in the past 5 seconds : 29%
CPU Utilization in the past 60 seconds Average Utilization : 21% Maximum Utilization : 30%
Alarm Status Current Alarm Status : Off Last Alarm Start Time : Dec 14 23:45:35 2019 Last Alarm Duration Time : 13 seconds
Alarm Configuration Rising Threshold : 90% Falling Threshold : 70%
"CPU falling trap." level : 6, module : 5, function : 1, and event no. : 1 [1926] 21:45:00 2019-12-14 "CPU rising trap." level : 6, module : 5, function : 1, and event no. : 1 [1925] 21:38:59 2019-12-14 "DHCP packet length(42) is shorter than 264, drop" level : 3, module : 134, function : 0, and event no. : 0 [1924] 21:38:51 2019-12-14 "DHCP packet length(42) is shorter than 264, drop" level : 3, module : 134, function : 0, and event no. : 0 [1923] 21:31:33 2019-12-14 "DHCP packet length(42) is shorter than 264, drop" level : 3, module : 134, function : 0, and event no. : 0 [1922] 21:31:23 2019-12-14
Hardware Version : R3.00 EPLD Version : 0.00 Number of Ports : 28 Main Power Status : Up Role : Master Loader Version : 1.0.6.0 Linux Kernel Version : 2.6.22.18 Boot ROM Version : 0.0.0.1 Operation Code Version : 1.5.2.16
Як наслідок в абонентів короткочасно втрачається доступ до мережі Інтернет Періодично втрачається доступ до обладання.
Конфіг: interface ethernet 1/1-24 no spanning-tree loopback-detection switchport ingress-filtering no spanning-tree port-bpdu-flooding spanning-tree spanning-disabled spanning-tree bpdu-filter mvr domain 1 type receiver network-access mode mac-authentication ip source-guard sip-mac
loopback-detection
interface ethernet 1/25 switchport ingress-filtering switchport mode trunk switchport acceptable-frame-types tagged switchport allowed vlan add 1,199,251,1540 tagged mvr domain 1 type source ip dhcp snooping trust
ip dhcp snooping no ip dhcp snooping verify mac-address ip dhcp snooping vlan 199,1540 ip dhcp snooping information option ip dhcp snooping information option remote-id ip-address encode hex ! mac-authentication reauth-time 86400
